1st year in business
Discussion in 'Ask An Owner Operator' started by LumbraX, Dec 3, 2015.
  1. LumbraX
    LumbraX Medium Load Member
    394
    443
    Sep 12, 2015
    Orlando, FL
    Last year on December 4th I purchased my first truck at age 25. A 2008 Volvo VNL 630 with 749,000 miles. It was one of the lucky ones built in Jan 2007 so it didn't have DPF.
    Here are my horror stories:
    Day 1: First day doing Intermodal at CSX Winterhaven. Extremely nervous.... Picked up first container and as im pulling out a driver is running up yelling at me to stop... Get out... Power steering fluid everywhere. Blew a hose. ($60)
    Week 2: Truck starts making a awful noise. Had to be towed. Come to find out when Freightliner Tampa sold me the truck the people who shipped it never tightended the steer tires lug nuts. (YEAH my right steer tire was about to FLY OFF) Truck needed new wheel hubs\lugs and studs. It was taken to Rush in Winterhaven and it only took 2 calls to freightliner threatening to lawyer up for them to cut a check. (They did the DOT inspection in house) Repair and tow bills covered in full. (Around $3200 including tow)
    First Month: AC quits working... While driving I get a Low Coolant light. The cooling tube is so corroded its leaking. Luckily i have tons of water in truck. Took duct tape and zip tied it which stopped the leak enough to take it to rush. Ready for this..... ($900+) 1 cooling tube :( but ooooh well we had to retread the mounting slot because it was so corroded.
    Month 2: Truck keeps slowing loosing coolant. Take it to Nextran Auburndale. Needs new Radiator, Expansion Tank, one of the egr hoses, new transmission feed and return lines and they diagnois the AC. Total repair would of been over ($6000). Paid over $3000 just because i didnt have them fix AC.
    Month 4: I find a cool mechanic just a couple of years older then me on craigslist. Volvos are his specialty he says. Ended up giving him the nextran AC diagnosis and he fixed everything for ($1200)
    Month 5: AC quits working. Take it to my guy he loads it up with Dye then I take it out for a week. It needs new Evaporator in the sleeper. While trucks there I get 2 new service hoses\glad hands and have 8 Gabriel Gas SLX shocks installed. New wiper blades also...Around ($700)
    Month 6: Leveling valve is pissing out air... Another cheapish fix. Then 2 days after I get truck back a rear air bag blows lmao.... Dude fixed the leveling valve but I took truck to Nextran for the airbag ($450 total for both parties)
    Month 7: EPG hose is leaking. D12 sounds like a jet engine while warming up. Simple fix though ($100)
    Month 9: Front mudflap bar falls off on interstate and takes a chunk of retread off. Truck goes in for 90 inspection (Quit doing Intermodal at this point) and they fail me for the tire.. A running light (Definitely a harness issue) and a small air dryer line was leaking. Didnt want to drive to Tampa for repairs (I park truck in Orlando) so i screwed up again and took it to rush. ($511 for the harness and hose... Guess they had to replace tail lights as well because Volvo changed the prong design with harness) Took truck to Goodyear for a used tire. Found obe for $125.... $30 Install... Sure enough right on time... A handful of lugs were stripped. Had all 10 studs and nuts replaced at an additional $60
    Did 2 PMs since Ive owned it so lets estimate another $600.
    I got into driving at 22. (Werner ENT, Pullen Brothers, Save a Lot Dedicated)Went to Roadmasters at 21. Ive been on this forum lurking for years and talked to hundreds of drivers on the road. It's absolutely no joke how much big money it can cost to operate these trucks. At the end of the day im still here though!!!!! If you noticed also. The truck hasn't broke in 3 Months..... Hoping I have all the bugs worked out. Plan on going fully independent this year once I can trust the truck. Wish me luck
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Sounds like the worst is behind you
    It's all gravy from here Lol
    Straight Stacks and LumbraX Thank this.
  4. Rock 'n Roll Relocater
    Rock 'n Roll Relocater Medium Load Member
    481
    5,875
    Nov 16, 2015
    Near Music City
    You must be trying to jinx yourself! :biggrin_25524:
  5. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    Looks like a typical cost for a year of repairs.
    Good luck
    LumbraX Thanks this.
  6. LumbraX
    394
    443
    Sep 12, 2015
    Orlando, FL
    lol... Honestly though... At this point nothing is a surprise
    Rock 'n Roll Relocater Thanks this.
  7. Rock 'n Roll Relocater
    481
    5,875
    Nov 16, 2015
    Near Music City
    I know what you mean. When I bought my truck I was guaranteed it was in 'tip top' shape. I think they meant if it were lined up with trucks waiting to be crushed. :biggrin_25523: My first lesson was that no matter what the problem is the LEAST it will cost is $500. Bad hose? $500 Alternator? $500 I thought I was going to go broke for the first three months.....lol
  8. LumbraX
    394
    443
    Sep 12, 2015
    Orlando, FL
    When I was leased to the Intermodal company another guy there with a older Volvo 660 I believe, gave his local mechanic anywhere from $150-$250 a week as an escrow and he's still in debt...
  9. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Should've bought a CAT Powered Pete 379. What's wrong with these young guns!???
    7-UP, truckon, Highway Sailor and 5 others Thank this.
  10. xsetra
    5,198
    7,150
    Aug 21, 2011
    LumbraX so much cost is dependent on truck, Never know when, where or what will need fixed. I just ran 1000 miles home to have my transmission fixed at local shop that I know and they know my truck.
    Should do that more often I got 7.8mpg running empty. Best I have ever done. hahha
    Preventive maintenance is the best way to keep the wolves at bay. Just continue to fix the little things and hopefully the big bills won't come.
  11. Rock 'n Roll Relocater
    481
    5,875
    Nov 16, 2015
    Near Music City
    You buy what you can afford, or what you think you can afford. I wasn't planning on staying in it for more than a couple of years, and I didn't. After my wife got pregnant I sold it and got a job as a company driver doing a local run so I was home every night. So much for showing my wife the country.
    :Straight road:
