2 CDL Jobs HOS Rules?
Discussion in 'Trucking Industry Regulations' started by Berniemacman, Mar 21, 2018.
  1. Berniemacman
    Berniemacman Bobtail Member
    43
    Feb 7, 2012
    I might have the opportunity to work for a Mail Hauling company from 1am-9am(MTuW), and 2am-8am(ThFSa) and a Intermodal job from 6pm-11pm(TuW) and 6pm-1am(Fri) and 6pm-3am(Sa). Both of these jobs will be local not driving more then 50 miles from truck terminal. It will be a total of about 65hrs, will I be able to work this does it fit into HOS rules going from Overnight job to Early morning job? Mail hauling uses E-logs and Intermodal uses paper logs.
    Also will I have to take a 30min break even if I'm gonna be running 50mi radius local and no more then 9hrs/shift?
  3. shogun
    shogun Road Train Member
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    It’s only illegal if you get caught. Seriously, though, once your 14 started you have to log it accordingly. Meaning you would be in violation Tuesday, Wednesday, Thursday, Friday and Saturday. You cannot drive after 14 hours, and you don’t have long enough rest breaks. If they were back to back schedules it would be more feasible.
    That being said, others have done it. It’s not a problem until you have an accident and they do some checking.
  4. Berniemacman
    43
    Feb 7, 2012
    What if I was to start 2nd job at 7pm, giving me a 10hr break from 1st job(9am-7pm). And new 14 clock good until 9am the next day?
  5. shogun
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    so you would work 1am to 9am, then take 10 hours and come back in at 7 pm. You could then work til 9 am the next day, but you can’t drive after 9 am until you have taken 10 off again. Then you would just need to keep track of your 70 hour clock.
  6. Berniemacman
    43
    Feb 7, 2012
    Alright, thank you very much for your help.
  7. shogun
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    No problem, hope it works out for you.
  8. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Need to carry both logs with you too if you want to be completely legal. So, you would need to email your elog to yourself daily. And carry the paper log in the other truck.
    If you were to be in an accident, or do anything that gets CSA points, chances are good both companies will fire you. Companies are funny sometimes and won't like you risking their CSA score working for another company.
  9. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    so if I have two trucks I cant have a log book in each one ;)
    Roger McG and Bean Jr. Thank this.
  10. Ridgeline
    22,733
    123,587
    If you are within 50 miles of your terminal, why are you using logs?
    The real deal is once you clock in, you are considered working and your 14 hour work day rules. Ten hours off.
  11. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Within 50 miles of your terminal you don't need logbook at all unless state law is different
