2 check engine lights on and my DEF fuel light on but I just filled DEF tank
Discussion in 'Freightliner Forum' started by Andy at ABC TOWING, Aug 4, 2016.
Page 4 of 5
Welp same issue just brought me here... 2 amber engine lights were on at first. I was having problems going over 55 mph too. Didn't think anything of it because I was hauling uphill.
About 50 miles in, the DEF starts blinking, but my DEF tank is full. While reading this thread & preparing to see my pockets get lighter, the DEF light just stopped blinking. #RandomAF
Guess I'll be changing the sensors, inspecting the wiring & cleaning the connectors. Does anyone have any part numbers? -
Yeah sounds like sensor's , any codes on the dash?
Absolutely...
ENG 1 SPN 2631 FML 1 - Low Air flow
EEC 61 SPN 4364 FML 18 - NOX sensor
EEC 61 SPN 3364 FML 2 - Bad DEF quality
I got fuel & DEF at Love's in Pecos, TX. Spent a 10 in Van Horn. Started up & had all these codes & engine lights. Did a parked regen in El Paso.
Pointed her East, set the cruise to 70 & I've made it to Midland so far without any issues.. -
Wow , when my sensor wires were chafing and shorting out I got a bunch of funny codes on and off , sometimes they would clear other times not . Eventually went into limp mode many miles later . Changed bothe sensors and reset light and all was good . GoodluckGameDayDog Thanks this.
Well.. i didn't do anything but the parked regen.. I picked up my next load in Dallaa. Started the truck & all my codes had cleared.. Knock on wood she stays that way for a week or two.. hahaha
Fun stuff ! Geez
How do you do a forced regen? I have 2011 with dd15 won’t do a regen
Also I have the two yellow engine lights on and a flashing yellow light on my DEF gauge and I have one code that is EEN 3361
You might have a derate soon , could be faulty wiring or the metering unit . There is another thread if you search ( spn 3361 ) I believe the guy disconnected his speed sensor to get home and get it fixed .
Page 4 of 5
