2 more autoshift / smart shift questions.
Discussion in 'Experienced Truckers' Advice' started by 04 LowMax, Nov 14, 2021.
  1. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    With the freightliner smart shift, can you start off in L and then go into D on the go without hurting anything? It starts way smoother in L with a load than it does in D. (13 speed). And # 2, is it ok to slip it into N and coast to a stop? Not at a red light I'm talking about when you're going to be parked. Thanks.
  3. Kyle G.
    Kyle G. Road Train Member
    3,902
    20,578
    Jan 23, 2016
    Eastern Iowa
    I’m no mechanic, but in my experience the computers in these newfangled auto shift trannies will not let you do anything that will cause damage. For example if you are driving down the road and you put it into reverse and floor it, it will simply beep at you and not do anything. So if you give it a command, and it follows your command, it’s probably ok.
    But I’d be curious to see a response from an actual mechanic if my reasoning is correct.
  4. kylefitzy
    kylefitzy Road Train Member
    4,753
    19,806
    Aug 12, 2007
    Kansas city,Mo
    It’s been years since I was in a freightshaker with a smart shift. Both things were perfectly fine.
    Pamela1990 and 04 LowMax Thank this.
