2 pigtales?
Discussion in 'Flatbed Trucking Forum' started by Hurst, Nov 19, 2015.
  1. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I've been meaning to ask this for a long time now and kept forgetting.
    I have 2 pigtales for power coming out the back of my Columbia. I bought the truck from my carrier and asked him what the second pigtale was for?? His response to me?
    "I dont know" "Play with it and see what it does"
    My trailer has 2 plugs for 2 pigtales. I plugged the 2nd pigtale into the other port to see if it did anything. If it does,.. I have no idea what it does. The trailer does not have any extra lights or strobes on the rear. I thought maybe it was to power strobe lights or something. The trailer does not have any other external power plugs either. The regular flat I had before the step I have now had a plug in the rear for plugging strobe lights in, yet did not have the 2nd plug like this one does.
    So what the heck do I have,. and whats it for?
    Hurst
    Son Thanks this.
  3. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Always wanted to put a 2nd one on for extra toys. I assume you've already taken a test light to the leads.
    Hurst Thanks this.
  4. damil
    damil Light Load Member
    171
    248
    Sep 23, 2012
    could be a pigtail for a electric tarp for a grain trailer any clue what the truck did in its previous life
    Hurst Thanks this.
  5. whoopNride
    whoopNride Road Train Member
    1,649
    5,015
    Jan 13, 2008
    Miss.
    Dump valve ?
    Hurst Thanks this.
  6. catalinaflyer
    catalinaflyer Road Train Member
    2,278
    Wichita, KS
    I have 2 on my truck as well, the second one operates lift/dump axles on most of our trailers. I have a dedicated lift/dump switch then have a couple of the other pins wired to +12v switches on the dash that I use to power OD lights etc.
    Hurst Thanks this.
  7. TripleSix
    133,284
    I have 2 pigtails. One is the normal pigtail that all trucks have. The other is to power a steerable trailer.
    Hurst and Straight Stacks Thank this.
  8. MACK E-6
    50,025
    238,257
    So do I.
    One powers the liftgate. :D
    misterG Thanks this.
  9. frt60
    frt60 Medium Load Member
    312
    266
    May 22, 2014
    If you take the vin number to frtliner they can print out a wiring diagram for you
    Hurst Thanks this.
  10. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    On my truck the second one was/is for antilock brake systems on some trailers. Its a 2000 379 pete. I've never had to use it for that. IIRC when they first came out with abs there was worries about powering up that circuit. Now they just get power off the brake light circuit when you step on the brake. I used to use mine for running extra lift axles on my trailer
    Hurst Thanks this.
  11. TaylorMade407
    TaylorMade407 Road Train Member
    1,328
    1,036
    Jun 30, 2009
    Orlando,FL
    Dump valve more than likely
    Hurst Thanks this.
