2 Violations for the same thing. 8 points together.
Discussion in 'Trucking Industry Regulations' started by Truckerchuckdontgiveaf, Jun 3, 2021.
  1. Truckerchuckdontgiveaf
    Truckerchuckdontgiveaf Bobtail Member
    Jun 3, 2021
    I got my first class 1 inspection, I got two violations. The Dot officer looked at me and said “no big deal”, that was screwed up.! come find out it’s a huge deal!!! “Just get it fixed when ever your at your home shop.” I got a Clamp or Roto type brake out of adjustment ticket and CMV manufactured after 10/19/94 has automatic air brake adjustment system that fails to compensate for wear Ticket. How can I get two violation for the same thing, worded differently. Can one even happen with out the other? 8 points together.! My driving carriers shot.
    NavigatorWife Thanks this.
  3. kemosabi49
    11,024
    48,152
    Jan 13, 2013
    SW Arkansas
    Did you get an actual ticket? A citation? If so you can go to court and fight it. If you just got an inspection form listing the two violations, you can try to DataQ it. Not much else you can do.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Overreact much?
    Go get it fixed and continue on with life. Nothing is going to happen to your career. Likely nothing is even going to be mentioned by your employer either.
  5. Dave_in_AZ
    432,675
    8 points is nothing. You're career is not ended lol.
    Sounds like you have a bad slack adjuster. Like $200 at any shop or TA.
    We do anuals every 120 days that helps to head those type of gripes off before the DOT man finds them.
  6. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,967
    Nov 1, 2017
    The Sticks, Idaho
    You have 2 seperate issues so got 2 seperate violations... It just happens that they both have the same cause.
    Issue 1: Brake out of adjustment.
    Issue 2: slack adjuster that doesn't adjust.
    Problem: slack adjuster is wore out, broke or otherwise inoperable.
    Solution: a couple hundred dollars and a couple hours at a service facility.
    As the DOT said.... "No big deal"... It's not like you got put OOS.
  7. bryan21384
    bryan21384 Road Train Member
    15,894
    34,648
    Sep 18, 2009
    Memphis, TN
    It's only 8 points. The points will fall eventually. Get your truck checked out, clean it up, and do better. That's all. Where'd you get inspected?
  8. Cattleman84
    10,057
    71,967
    Nov 1, 2017
    The Sticks, Idaho
    I wonder if this driver is equating CSA points to drivers license points like one gets for getting a speeding ticket???
    If so OP... They are not the same or even remotely close to the same. 8 points is nothing to sweat.
  9. AModelCat
    165,592
    That's what pre-trips are for.
    NavigatorWife, Flint1, alds and 2 others Thank this.
  10. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Isn't the pre-trip the trip to the restroom before you leave on the road?
  11. Truckerchuckdontgiveaf
    Jun 3, 2021
    By Louisville.
