2000 379 A/C fan speed issue
Discussion in 'Peterbilt Forum' started by Geckolyn, Apr 22, 2013.
You're blower resistor is bad you just need to replace it its actually really easy it should be located somewhere right near the blower motor.
open and pull down glove compartment.5 min.job.unplug,remove 2 phillips screws,replace.good luck.
to test ot fix as temp run a jumper wire around each post.
My 86 Toyota Tercel did the same thing . Changing that resist fixed it.
