2000 379 hvac blower problems
Discussion in 'Peterbilt Forum' started by Pete00369, Apr 10, 2017.
  1. Pete00369
    Pete00369 Bobtail Member
    19
    4
    Jul 11, 2013
    on my 2000 Pete the ac blower won't work I changed the blower it self and didn't work, I changed the resignator to the blower and still didn't work today I changed the fan speed switch thinking surely this is it and the #### thing still won't work the ac conprsor will turn on with the switch but the fan won't run any ideas??
  3. slickWillie1980
    slickWillie1980 Medium Load Member
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
    Is the fan running backwards? It's a silly question but have a reason for asking
  4. Pete00369
    19
    4
    Jul 11, 2013
    No it's not running at all changed relay too just seems like it dnt have any power!!
    slickWillie1980 Thanks this.
  5. 86mechanic
    86mechanic Medium Load Member
    373
    62,256
    Sep 6, 2016
    Northridge, CA
    Did you check the fuse and ground?
  6. slickWillie1980
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
    As stated it could be a fuse or bad ground. If you are handy with a multimeter then that could be figured out pretty quick
  7. Pete00369
    19
    4
    Jul 11, 2013
    I didn't check the ground the relay I changed before it stopped working before it only worked in high and would cut on and off cause it would make the relay hot where would the ground be at
  8. 86mechanic
    373
    62,256
    Sep 6, 2016
    Northridge, CA
    I read somewhere that peterbilts have a constant hot on the blower motor and the fan control is switching ground. So you can take a testlight or voltmeter and check the wires going to the blower and see if one of them has constant power.
  9. Pete00369
    19
    4
    Jul 11, 2013
    I did that but it seems to be very weak power going to it I did it with Testlight of course
  10. 86mechanic
    373
    62,256
    Sep 6, 2016
    Northridge, CA
    Could be a bad wire. Check at the fuse and see if you have good power there.
  11. Pete00369
    19
    4
    Jul 11, 2013
    I figured it changed the fuse and still didn't work so I called a buddy of mine and he told me to get behind the fuse block and check the wires and clean back there cause a lot of dirt and crap get back there and sure enough had a bad sore so just fixed it and it worked!!! Thanks guys for y'all help!!
