2000 379 peterbilt mode actuator location
Discussion in 'Peterbilt Forum' started by fatal, Sep 16, 2021.
  1. fatal
    fatal Bobtail Member
    9
    Sep 16, 2021
    I pulled off the glove compartment but don't see it. which is where the Pete dealer told me it was.
  3. bad-luck
    bad-luck Road Train Member
    3,455
    6,375
    Nov 16, 2013
    Baltimore, Maryland
    When you say mode actuator what exactly do you mean? What is the problem with your truck?
  4. fatal
    9
    Sep 16, 2021
    yeah, the fan switch won't switch to floor, floor/vent, or vent. it will only do defrost and defrost/floor.
  5. lester
    2,957
    8,089
    Jan 2, 2012
    NW, Iowa
    It should be there. Some where on top of the duct work past the fan. Little odd shaped flat on top thing, has a circle on top about the size of a pencil eraser I think. That is the part that turns to move the door to switch from floor, vent etc... that's all if memory serves me.
  6. fatal
    9
    Sep 16, 2021
    okay, it's on the other side of the fan, closer to the engine. I'll check that out.
  7. bad-luck
    3,455
    6,375
    Nov 16, 2013
    Baltimore, Maryland
    Ok, that is what I thought but wasn't sure. You need to remove the plastic cover that is underneath the glove box. It is where the small cover that you take off to replace the cabin air filter
  8. fatal
    9
    Sep 16, 2021
    those two are for the temperature and something else I can't think of right now. not the blower location.
  9. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    yes, that is the blend door actuator for temperature and the other actuator is the fresh air and recycled air door
  10. bad-luck
    3,455
    6,375
    Nov 16, 2013
    Baltimore, Maryland
    Ok, I have replaced the blend door actuator several times on my 2000 379 but never the temp actuator. You have to remove the glovebox to access the blower motor.
  11. fatal
    9
    Sep 16, 2021
    yeah, I did, I just don't see it. I did see a metal plate but I had to get rolling. I'm going to check that when I'm done tonight.
    bad-luck Thanks this.
