2001 9400i A/C problem
Discussion in 'International Forum' started by 46beezer, Sep 19, 2013.
  1. 46beezer
    46beezer Bobtail Member
    5
    This truck came in low on freon. Filled system. Compressor will not come on. There is no power to compressor. Jumped compressor and it will engage. I have power in and out of thermo switch at evaporator. Tapped on pressure switches, unplugged switches and no change. It will eventually engage the clutch for a split second, wait 30 sec. or so and do it will do it again, sometimes. This truck has the a/c module by the coolant tank. I reset it and it will flash red again 3 times.
    Any help appreciated.
    Randy.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    U may not have enough in yet.
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    If it is flashing 3, that should be for open,or short circuit between the APADS module and the compressor clutch. The module will send power out to the clutch from the 6-wire connector, blue wire. If you can jump power at the clutch and it works, chances are the clutch wire is rubbed through somewhere across the engine between the module and the compressor.
  5. 46beezer
    5
    I jumped the wire and the compressor engaged. I checked for voltage at the blue wire after the module and there was none. I pulled apart the connector (difficult) and one of the pins was broken. I snipped the wire and made a seperate connector for it. Reset the module, started truck and now the module flashes four times, open to pressure switch. Maybe I'll get some new switches and see what happens.
  6. Heavyd
    7,829
    6,280
    Feb 4, 2009
    Frustrating, isn't it? If you get new pressure switches make sure you get the right ones, trucks built with APADS have special switches.
