2001 Cummins N14 will not start, engine warning light on.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mission_creek, Feb 22, 2021.
  1. mission_creek
    mission_creek Bobtail Member
    44
    14
    Feb 22, 2021
    Parts department was running behind, just got it in the truck and STILL not wanting to start. Really got my hopes up there.
  3. jamespmack
    216,582
  4. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    Check the fuel pressure at the shut down solenoid during cranking. Needs 25psi to start
    tommymonza Thanks this.
  5. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    How about checking for voltage to the solenoid first
    tommymonza, jamespmack and jsnell Thank this.
  6. jamespmack
    216,582
  7. mission_creek
    44
    14
    Feb 22, 2021
    Sorry I haven’t had time to check the fuel shut off solenoid today, had to dig a pond. Wound up taking the air compressor, charging up the brakes, hooked a chain to it and pulled it away from the trailer and hooked up the international. It might be a couple days before I can get back to it, unless I make it home before dark.
    jamespmack Thanks this.
  8. mission_creek
    44
    14
    Feb 22, 2021
    Fuel shut off solenoid is at 12 volts, solenoid clicks when wire is touched. I keep thinking it’s a fuel issue...but it turns over exactly 3 times and fires for a second, every single try. I got a good look at the gauges before I shut it off and everything was where it was supposed to be, besides the solid red engine warning light. Is there a low fuel pressure light or would it trigger the check engine light?
  9. pup
    252
    256
    Dec 3, 2011
    n.h.
    The ecm doesn't know fuel pressure. There isn't a sensor. Is the red warning lamp the stop engine lamp or a low oil pressure lamp?
  10. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    Don't rule out fuel lines and pickups.
    If you fill the fuel filter does it run at all ?
  11. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Put a hose in a bucket of fuel and see if it'll run that way, so you can narrow it down.
