2001 Freightliner FLD120 Highbeam Issues
Discussion in 'Freightliner Forum' started by Lezperado, Jun 26, 2024.
  1. Lezperado
    Lezperado Bobtail Member
    I have a 2001 Freightliner FLD120 day cab. When I turn my high beam switch on, my low beam and my high beam on my driver side both go out but the passenger side works. I switched the relays to either side and it still happens. Where do I go from here?
  3. Bro_Dave
    Bro_Dave Medium Load Member
    530
    524
    Nov 5, 2013
    I would say the switch is probably bad.
  4. jamespmack
    Clean plugs at headlight or maybe replace them.
    QUALITYTRUCK Thanks this.
  5. Rideandrepair
    17,584
    56,954
    Aug 8, 2015
    Shorted wire between the drivers side plug at either headlight and the splice that goes to the passenger side. Start with a test light at the plug(s) work your way back till you have constant power. Replace wire. Or just buy a whole new harness. Kind of expensive, but will save a lot of headaches in the future if you plan on keeping it a while. Every one I’ve seen has been patched up, including mine. Only a matter of time before another short or broken wire causes problems. Harness is plug and play. Runs to Drivers side and another plugs into it runs along the hood over to passenger side.
  6. IH Truck Guy
    5,065
    58,949
    Mar 2, 2008
    Purgatory
    Check the wires where the hood hinges are.
    They like to break there where they bend.
    Rideandrepair Thanks this.
