2001 Freightliner no power to AC compressor please help!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Adamjorgy, Mar 24, 2015.
  1. Adamjorgy
    Adamjorgy Bobtail Member
    16
    When I slide my lever over to AC the compressor clutch won't engage.. There's no juice coming to it and the free on is full any help would be appreciated
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Look on top of dryer and unplug wires to see if power is getting that far, if it has 12v. there you may cross the wires temp. to ck. if ac. clutch kick on?
  4. Thed302
    Thed302 Light Load Member
    114
    70
    Oct 30, 2014
    USA
    Check your low pressure switch if it has one.
  5. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    Get a multi meter, test light or power probe. Do you have a/c gauges?
  6. Oldman49
    Oldman49 Medium Load Member
    353
    300
    Jul 20, 2014
    Had lots of problems with the fuse block on the dash that fed the compressor. Wiggling the big fuse might make it start or stop. Eventually a burned terminal underneath the block had to be repaired/replaced.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    In addtion to what was already mentioned, some older FLD's had an air pressure swtich that would not allow A/C until air built up enough for the fan to work properly. I've only seen that on air engauged fan hubs.
  8. Adamjorgy
    16
    I have power at the dryer with AC on.. I can't get hardly Any air out of my vents in the cab checked all flaps and everything for blockage and nothing.. The fan runs to beat hell though.. Not sure if that would have anything to do with it or if that's a separate problem.. Thanks for the help so far guys
  9. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    2001 FLD has a/c control box and it is the same one that goes on early version centuries. 12 v positive wire goes from that box to fuse box and from there to a/c clutch. also there is a diode on positive wire on fan clutch. a/c control box is located in dash on passenger side and sometimes under cab- right front corner( under passenger foot). its a cigarette box size piece and costs $120 at dealer.
  10. Hammer166
    7,606
    27,796
    Aug 18, 2007
    ~8600+' and loving it!
    There's two switches in the clutch circuit, a high pressure and a low pressure. Either one of those is bad, you won't get power to the clutch.
  11. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    If you don't have power at compressor go to the binery/trinary switch. Gotta have power in and power out. If power in and none out bad switch or low on Freon. If you keep backing up with tester will find problem. My old pete 359 has an off on fan switch witch has to be on for AC.
