My grandfather has a 2001 freightliner with the isx 500 with 650,000 miles. We just replaced the turbo because there was oil in the outlet and thru the intercooler tubes. It has a lot of blow by. To put into example it is just a solid stream and makes a cloud around the truck. We are wondering what has happened to the truck because most of it has happened all of a sudden like the oil in the turbo outlet. Hope somebody can help. Thanks
2001 isx problems???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cummins21, Nov 7, 2010.
seal damage is usually caused with bearing play ore turbine disballance. Before it happens turbine is lowder then usually.
But 650k it is a long life for turbine! change and do not worry for next half million miles -
What about a very leaky fuel injector?
sorry forgot to say that this was after the turbo was changed and before the turbo was changed.
Paddletrucker Medium Load Member
If it was a 2001, wouldn't it be an N-14? I thought the ISX didn't come out 'till 2003 or so. Maybe I'm wrong, I don't run a Cummins. Would it make any difference if it was an ISX or an N-14?
ISX came out in 2000. I never blew out the turbo on any truck I have been around in 30 years. Put 1.4 million on a '96 N-14 and it still had original turbo when I crawled out of it. My current ISX has around 627,000 on it and turbo still doing just fine. Now, watch me have to eat my words since I brought it up!!
seems to me old engines were better...
