2002 D12D can not be started. Need help
Discussion in 'Volvo Forum' started by Carport, Feb 13, 2015.
  1. Carport
    Carport Bobtail Member
    22
    Nov 23, 2014
    At beginning start was difficult by malfunction of electrical fuel priming pump after tank refilled from empty. Then it worsen for a week even still fuel in the tank. Fuel was forced by high pressured air from air compressor into tank for starting aid. Now cranking but no combustion and can not be started. No smoke through exhaust pipe during cranking. All measurement are same voltages between high and low sides on all injectors either between injector and frame key in drive position. MID128 SID 78 FMI 5, MID128 PPID122 FMI 5, MID128 SID18 FMI 5, MID128 PID 94, FMI 4 codes are shown. Also we had incorrect connection on batteries and little blown by short circuit. What would be damaged by this?
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Well if the batteries were hooked up wrong maybe fried the ECM? Also I think there's a smaller fuse on the positive cable itself that if fails will shut the truck off.
  4. Cali kid
    Cali kid Road Train Member
    1,738
    2,380
    Feb 15, 2011
    IE, CA
    They are just a pain it happened to me once took two days to get it going. They were spraying it with a crap load of starting fluid.
