2002 rear hazard lights are not working, but all other harard lights do. Even trailer please advise Thank You
2002 hazard light issues
Discussion in 'Volvo Forum' started by Robert770, Oct 17, 2018.
Unplug that plug (it’s a plug and clip style plug with about 4 wires on both ends) and turn on/ run your hazard lights. Test for voltage on the truck side of that plug. You’ll have to test each of the four or so leads on the plug to find out what is what. BUT, if you catch a blinking (hazard light style flash) 12v signal on the truck side then u know the issue is after the plug and on towards the rear of the tractor. Could be a shorted wire grounding out, touching metal somewhere etc -
check hazard switch connections in the dash, everything goes seperate also there is a seperate fuse.
Check Fuses 64-65-66-67 first
