2002 Pete 379 Battery/brake issue
Discussion in 'Peterbilt Forum' started by sloshed, Sep 20, 2024.
  1. sloshed
    sloshed Light Load Member
    56
    11
    Aug 5, 2013
    good point
    I'd almost certainly do that before the harness... I'll keep that link in mind
  3. Ky Flash
    Ky Flash Bobtail Member
    46
    53
    Apr 13, 2016
    Check with Hunter Peterbilt in Lancaster PA I've got a 03 and they ordered the correct cables for me company made them
    Oxbow Thanks this.
  4. bjytech
    bjytech Light Load Member
    249
    225
    Nov 9, 2013
    Honestly, when those jumpers inevitable corrode like that what I do is put a regular jumper wire in and then there has always been more than enough wire on the smaller gauge wire that comes off it to just cut the plug in connector off and put a simple eyelet on the end and connect it to the battery that way.
    Just keep it simple.
    Oxbow and Goodysnap Thank this.
  5. lester
    2,959
    8,099
    Jan 2, 2012
    NW, Iowa
    just get new cables and hard wire the other connectors. it's ECM power and anything else that's been hacked into the truck over the years
    Oxbow Thanks this.
  6. Goodysnap
    Goodysnap Road Train Member
    3,811
    9,296
    Jul 12, 2017
    Put some holdowns on the batteries and the cable jumpers won’t break like that.
  7. Cdemars316
    Cdemars316 Road Train Member
    1,134
    7,689
    Nov 10, 2018
    Agree with the hold downs, ended up doing this on the road with a strap and getting home and doing it the right way. Keeps everything in there from moving around and the battery box already has holes in it for the rod to go through the bottom
    sloshed Thanks this.
  8. FLHT
    FLHT Road Train Member
    1,480
    2,716
    Aug 2, 2014
    Don't forget they like a good bath now and again..
