2002 W900L load light/cargo light wiring
Discussion in 'Kenworth Forum' started by Superman77, Mar 17, 2022.
  1. Superman77
    Superman77 Bobtail Member
    Hello and thank you in advance! As stated above, 2002 W900L daycare, has the factory switch to the right of the ignition switch that appears to be for cargo/load lights. However, day cab haul truck that has a headache rack on it that I am adding lighting to. Any suggestions as to where exactly I might find the pigtail/harness that the switch in question will control/activate? Anyone know exactly how said wiring should be labeled? I have looked under hood and frame rail, obviously to no avail. Just don't want to go thru the trouble of running wires, then someone smarter than me says "goofy ###, why didn't you just grab power from such and such marked wire that is located right there". Lol. My apologies for the lengthy post and again, thank you for any and all help in advance!
  3. Inderjit
    Inderjit Heavy Load Member
    772
    738
    Sep 17, 2017
    Is the switch a toggle or rocker? If its a toggle switch then the wire you
    are looking for should be located in the harness near the rear of
    the transmission. Its red with a gold stripe and the number/letters marked
    P14FL. It can be a pain to find if its tied up inside the harness. You will need
    to add a floodlight relay and fuse in the fuse box.
    If its a rocker then I'm not sure where the wire is located.
