2003 379 backup light switch replacement/18 speed Eaton
Discussion in 'Peterbilt Forum' started by Nevs, Jun 23, 2013.
  1. Nevs
    Nevs Light Load Member
    295
    108
    Dec 25, 2010
    flyover country (Iowa)
    As the title says, what is the best way to get to the switch? I can see it, and I'm guessing I need to remove the shifter cover to get to it from the cab, but given that none of the screws want to come out easily, I wondered if there was another way. Any and all thoughts are appreciated.
  3. boneebone
    boneebone Road Train Member
    2,297
    2,373
    Mar 13, 2009
    On my Eaton Fuller 13 Speed, which is the same as a 18 Speed externally, I crawled under the truck and accessed the Back-up Light Switch that way, you should just be able disconnect the Wiring Harness and unscrew the Switch from the top of the Transmission Housing.
    Nevs Thanks this.
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Yup crawl under the truck and reach up around the right side of the back of the trans you will have to go by feel pia sometimes
    Nevs Thanks this.
  5. oilfieldtrash
    oilfieldtrash Light Load Member
    226
    107
    Oct 17, 2009
    Jones,Oklahoma
    I changed mine 2 weeks ago through the shifter boot hole. PIA but I got it done.
    Nevs Thanks this.
