2003 379 led headlight issue
Discussion in 'Peterbilt Forum' started by Kurt schaneman, Apr 2, 2019.
  1. Kurt schaneman
    Kurt schaneman Bobtail Member
    19
    4
    Aug 28, 2015
    i have a 2003 379. The previous owner installed led headlights. When I bought the truck they worked awesome!! Then we started having an issue with the passenger side going completely out when the brights we’re engaged. Now if I turn the headlights on dim they are very weak. When I turn the brights off they go completely out. But the light on the dash comes on. The kicker is when I turn the marker lights on the heads lights go completely out. This truck is a bit of a wiring mess but I still don’t know where to start. Any help would be great!!
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Sounds like a bad ground. Find a lot of issues in the buckets and @ the hood hinges.
    AModelCat and pushbroom Thank this.
  4. Kurt schaneman
    19
    4
    Aug 28, 2015
    Ok I will look I just didn’t seem like anything was bad there but I will look again
  5. Deere hunter
    2,186
    10,710
    Aug 5, 2017
    Shallowater Texas
    Yes definitely sounds like a bad ground
  6. Kurt schaneman
    19
    4
    Aug 28, 2015
    I’m only getting 7 volts to the lights. At the relays. 1 pin has 12v 2 more have 7 and 1 has nothing...I checked all the wiring going to the lights and can’t find anything out of the ordinary? Also if I remove 1 of the relays for the headlights. Now they get a little brighter. And dimmer when the relay is replaced...is the fuse panel toast? Or still a ground somewhere? Where do I go from here?
  7. Luwi67
    Luwi67 Heavy Load Member
    752
    485
    Oct 24, 2012
    Long island
    I had a similar issue where the right side would go completely out when the brights were activated (I have the old double round headlights). I found on accident that if I wiggled the marker light relay the right side would come back on. I replaced the marker light relay and the problem went away.
    Someone had mentioned to me that the relay that was in there maybe wasn't rated properly for that circuit. I never bothered to check as the lights were working fine until now. So now I have to start figuring out why again.
    Low beams fine on both sides, turn on high beams and right side completely goes out left side is fine. Swap lights from right to left and same thing so it isn't the lights themselves. I don't understand what the marker light circuit has to do with the right side headlights. One thing I noticed is the fuse box itself around the marker light spades was brown like it was over heated.
  8. Peterider81
    Peterider81 Bobtail Member
    19
    13
    Dec 3, 2019
  9. Peterider81
    19
    13
    Dec 3, 2019
    I bought some LEDs to put in my pete 386 they work well on low beam problem is they won't switch to high beam. I bought error cancellors hoping to correct it but still same issue put different set of led bulbs in same so just returned them until i figure out what the issue is why they will not switch to high beam. Has anyone else had this problem with their led bulbs.
  10. Roosterrenihan
    Roosterrenihan Bobtail Member
    Peterbilt 386 came from factory with 9007 bulbs. Chances are your LED’s are 9004 the difference is ground and low beam position. So basically you’re ground out one and using the other. When you go to re pin 9007 to 9004 pay close attention to the diagram you’re looking at cause half of them on the internet are wrong. Trust me I fought this for along time.
  11. Peterider81
    19
    13
    Dec 3, 2019
