2003 columbia with bendix air Dyer
Discussion in 'Ask An Owner Operator' started by henboy1, Mar 10, 2021.
  1. henboy1
    henboy1 Medium Load Member
    332
    139
    Mar 26, 2011
    stockbridge
    not getting power to my clutch . I have checked just about everything . I checked the 30amp big fuse and the small one . Hvac fuse 1 and 2 is only for the front blower and sleeper . I havnt jumped the binary or the high pressure switch but I do know the high pressure is not getting power to it . Tomorrow morning I will check the pigtail at the binary switch . I followed the pigtail that goes to tje compressor,...no , the other end is not grounded to my starter
  3. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    Sorry. This is an sc clutch problem and not brakes
  4. AModelCat
    165,389
    Is the system charged? If the refrigerant charge is low the compressor clutch will not receive power either.
    Dino soar Thanks this.
  5. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    yes, it's got 100psi of refrigerant
  6. Dino soar
    Dino soar Road Train Member
    4,817
    27,071
    Dec 8, 2017
    Have you checked it with gauges? If it's overfilled it also will not work. Just because you added refrigerant doesn't mean it didn't leak out and it doesn't mean that you're not overfilled. If it is a Freightliner most of them take about five cans which is I think around 60 oz?
    If your truck is set up the same as mine the binary switch is what actually controls the clutch coming on and off. You will not normally have electricity at the high pressure switch especially if it is a Freightliner because they generally have a separate module that controls the fan. When the switch opens it tells that module to command the fan.
    You should be able to jump the wires with key on electricity without the truck running just to see if your clutch will engage. You should have electricity at the binary switch as long as the AC selector is in place with the key on. If you have electricity there and you have checked your pressure with gauges and you have jumped the wires and you see that your compressor does lock up then the binary switch is bad if your compressor won't start. Not sure if yours has a separate ground or not. Also again if it's a Freightliner there is an actual AC clutch relay that is in with the circuit breakers. If you have no electricity at the binary switch with the key on and the AC selected, then you have to look toward that relay..
    Was everything working and now it just won't work? Did you add more to the system or did you drain the system and replace parts and then refilled? Did you use gauges?
  7. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    I have had the truck for 12 yrs . Everytime I overfill with freon the clutches will cycle back rapidly and that's when I know I need to take some out ..the freon gauge shows 100psi when shut off. At that psi it it has always worked . I saw a fuse ( about 20 amp ) for the ac clutch and that has power ) . I also saw another big 30 amp fuse for the AC and that also has power . Hvac 1 and 2 is for the front and sleeper blower motor and not clutch . Not sure if the truck has a clutch relay , unless it's not labelled. I will jump the binary and the high pressure switch , but I doubt they will do anything . We will see this morning when I get to it .
