2003 Mack E7 power issues
Discussion in 'Mack Forum' started by niceguypmp3, Aug 12, 2018.
  1. niceguypmp3
    niceguypmp3 Bobtail Member
    43
    8
    Aug 31, 2009
    Weldon, IA
    On the 2003 Mack with a 350hp E7 and allison auto tranny that we just purchased a few days ago, i noticed driving it home that when pulling hills, then sometimes when you put the pedal down to pull the hill then the turbo spools up but then sometimes after 5 seconds or so then it will spool up even more and it has quite a bit more pulling power even though the tach doesn't move. It does it with the cruise on and also with it off so i don't see how it could be the pedal sensor. Could this be what they call a dual HP engine? Why would it be doing this? It didn't do it on every hill, sometimes it had the extra power immediately but other times it was delayed.
  3. Ok big boy
    Ok big boy Light Load Member
    101
    113
    Jan 22, 2014
  4. niceguypmp3
    43
    8
    Aug 31, 2009
    Weldon, IA
    I have looked on there but haven't posted about this issue. I will do that, thanks.
  5. Ok big boy
    101
    113
    Jan 22, 2014
    I owned a 2003 CX 613 with a E7 425 and a 10 speed. The engine was bullet proof , but pulling it would hesitate then I would feel some extra kick. I replaced the throttle position sensor. That helped quite a bit. I don't know if there is a way to test that. I do not know any thing about your automatic. I would be interested to see some replies. Good Luck!
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,062
    Nov 18, 2014
    Land of local
    Is it a 330/355 or a 355/380 maybe. Go to Rochester diesel and get a blixxton. Then if your still not happy they have injectors and a bigger turbo.
    Check for boost leaks 1st and take the charge air piping off and check the impeller shafts for damage and play
    Tuning & Modules | Diesel Injectors | Turbos | Nozzle Honing
