2003 T600 or W900 - flasher for turn signals?
Discussion in 'Kenworth Forum' started by rollin coal, Apr 3, 2014.
  1. rollin coal
    rollin coal Road Train Member
    13,685
    28,158
    Mar 29, 2008
    TN
    Where exactly is the flasher located? My turn signals get weak and stop flashing altogether after a minute or so. I've got a new one. Can hear it just not sure where the sound comes from.
  3. kwswan
    kwswan Road Train Member
    2,049
    11,276
    Jul 26, 2009
    mcminnville,tn.
    Take the panel off that is above the clutch pedal & it is in there or you can remove the gauge panel on the left of the speedometer and reach in there.
    rollin coal Thanks this.
  4. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    What he said. Basically in front of your left knee behind the engine fan switch, flood light switch etc.
  5. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Yeah, up there in the dash, iirc. Instead of by the fuse panel where everybody else seems to put them. Grrr...
  6. rollin coal
    13,685
    28,158
    Mar 29, 2008
    TN
    I can't find the #### thing. Aggravating. Pulled both panels dug thru jumble of wires. I can hear it but can't really pinpoint it. I'm wondering if mine has a different flasher in it than what they gave me for a replacement. Can't find anything in there that looks like the new one.
  7. eeb
    731
    268
    Mar 24, 2013
    Seems like it's up close to the firewall, maybe mounted to the firewall, iirc. In a rubber bracket/grommet thing. You'll probably see the wires going to it, better than the flasher itself. Good luck.
  8. dogofwar
    dogofwar Bobtail Member
    14
    4
    Jun 27, 2012
    Remove fuse panel and at the bottom you will see a row of relays , back of fuse panel will tell you which one it is .
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    It's directly above the diagnostic port, remove the two screws and drop that panel down. The style that your truck came with is different than what they are selling everyone now. I believe the old ones are screwed in that panel, the new ones have a ground wire on them.
  10. rollin coal
    13,685
    28,158
    Mar 29, 2008
    TN
    Oscar where were you at months ago lol. I never did figure it out. I had another more pressing issue I couldn't figure out at the time. What ended up happening is my low voltage regulator went bad. Which I had no idea because I'm lousy with electrical. I had the local CAT house diagnose and fix that. While they were at it they installed a new flasher per my instructions.
    Off topic, I know people may think to themselves why use a high rate shop like them? Because I have known and used them for years and they're the only shop that has never taken advantage of me. And also the only one that ever stood behind their work. Which they only had to do once. Rate for non-motor work is $30 an hour cheaper than the usual $115 per hour. Still a tad high but worth every penny in that they don't pad their time like the cut rate shops do (who ironically enough seem to average $100 an hour - funny how that works). They're worth every cent even at $115 an hour. Good shops are so hard to find.
  11. Manipal92
    Manipal92 Bobtail Member
    37
    30
    Sep 28, 2018
    Cant find it on my t600 2005. I dropped that panel , nothing screwed there except diagnostic port and some stuff, can’t see that black box similar to my replacement.
