Good morning I need help. Finding a troubleshooting guide for this volvo is impossible. The truck sucked the filters dry. I changed the filters and found sediment in water separator bowl. filled filters up truck started and sucked filters dry again. I tried primer button on dash and it doesn't seam to be working. Can anyone help he figure this wonderful piece of #### out?
2004 D12 wont start code is Sid 78 fmi 5
Discussion in 'Volvo Forum' started by ameritrux, Feb 21, 2019.
Check your fuel tanks to see if one of them is empty
Could have a collapsing fuel line. If thy have never been changed might start there, thy do deteriorate on the inside after a while.
Are the tanks full, half or close to empty. I've seen the aluminum pick up tube inside the tank break off and start sucking air when the tank is about half full.
Make sure not sucking air from a line or a pick up tube in the tank
Sounds like air from primary line check rubber o rings on connections just a clip that holds em together connectors do break good luck
