2004 kenworth, abs module location.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hughjazz, May 31, 2019.
  1. Hughjazz
    Hughjazz Bobtail Member
    32
    17
    Feb 12, 2017
    Can anyone tell me where I would find the module? I've got no abs light at all.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,892
    May 31, 2010
    West Harrison, In
    Most likely located under center console(cup holders). 2004, I believe ABS light is in warning gauge strip above drivers windshield. Did you make sure bulb isn't burnt out?
  4. Hughjazz
    32
    17
    Feb 12, 2017
    No I didn't check the light. I will, I wish it would be that simple. I'm almost certain the PO removed a lot of the components and wiring .
  5. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Yea, the light might be corroded out. Simple check. And test for power at the pig tail for that light.
    Is the dash board light cycling off/on?
  6. Hughjazz
    32
    17
    Feb 12, 2017
    Currently there is no light, no wiring from the sensors, and it looks the the air brake valve is a no abs type
  7. HopeOverMope
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Ten4. I hear ya on that
  8. Hughjazz
    32
    17
    Feb 12, 2017
    So some good news, the bulb was not pushed ask the way in. So I can confirm the ECM has power and the lights and relays are all working.
    The wiring to the pigtail is messed up somewhere, the centre pin has switched power from the dash for trailer backup light . But I'm very happy it seems like all the wiring in the cab is unmolested.
