2004 volvo 780
Discussion in 'Volvo Forum' started by vali, May 18, 2014.
  1. vali
    vali Bobtail Member
    7
    hi all
    i have a volvo 780 powered by ved12
    the truck starts ok some times but most of thr times i have to crank it foe a minute then starts and runs for a few min and die and its show on the display somteng like a fuel pump and 3 curly lines under that pump but my tanks are almost full
    i changr the filters and i check for a leak but noting found
    can anyone help please
  3. vali
    vali Bobtail Member
    7
    second problem is the auto transmision with cluch
    when i select the D or R the gear display the selected gear but flushes and its show a arrow down and noting hapen
  4. dorlia2
    dorlia2 Light Load Member
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    I would start with the fuel return valve.Page 7 http://www.thetruckersreport.com/tr...m/172562-05-volvo-truck-ved-d12-engine-7.html
  5. vali
    vali Bobtail Member
    7
    ok i have to try that
    i hope thats all
    thank you
  6. NoCoCraig
    NoCoCraig Road Train Member
    2,604
    1,695
    Nov 7, 2010
    Chattanooga, Tennessee
    On the clutch,you have what is called the AutoShift. check the small hydraulic reservoir on the firewall and make sure there is fluid in it. If low. add brake fluid. (DOT 3 or 4, does not really matter) Only holds about a half cup.
  7. vali
    vali Bobtail Member
    7
    thank you NoCoCraig
  8. vali
    vali Bobtail Member
    7
    i try that but the reservoar is full
  9. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    The pump with curly lines means air in fuel.
  10. vali
    vali Bobtail Member
    7
    i just order the return valv and all the o-rings for the feul lines
    hope thats all
    some one sed to me the injectors cupper cups are bed or the injectors, i hope not
  11. vali
    vali Bobtail Member
    7
    I did everything outside I could but nothing changed the same thing as before
    Anyone who has the same problem or experience in this case
    Please help
