2006 12.7 detroit issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Sega2010, Dec 7, 2013.
  1. Sega2010
    Sega2010 Bobtail Member
    25
    14
    Aug 8, 2012
    Got an 06 12.7 detroit with 344,000 miles on it has 10 speed.
    when i shift from 8th to 9th gear and from 9th to to 10 gear at about 1100 to 1200 rpm i get a delay like is sputters (as if you were to take your foot of the fuel pedal for a second) then a puff of black smoke once you accelerate for power, then once it goes past that rpm range runs great and it only happens in those gears. does it worse when loaded going up hills but also does it empty. any ideas so far ive been ignoring it bit starting to get worried. thanks
  3. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I'm pretty sure that in 2006, it was a 14L, not a 12.7.
    WAG on my part, it's likely something to do with the VGT.
  4. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    I don't think they had the 12.7 in 2006. It could be egr or vgt related.
  5. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    Does it have a DPF on it? I think 07 is when they started putting DPFs on so maybe not. If it does it could be that or the EGR. I'm just speculating of course but the Detroits that have the DPF seem to do this kind of stuff quite often. Thank you federal government for ruining a perfectly good engine.......sorry for the sarcasm.
  6. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    sounds like the vpod is going bad
  7. bad-luck
    bad-luck Road Train Member
    3,450
    6,366
    Nov 16, 2013
    Baltimore, Maryland
    It could be several things. First you need to make sure that the air cooler air charge system does not have any leaks. Then check clean and blow out the metal tubes fom the delta p sensor to the egr cooler. If this doesn't fix your problem. The delta p sensor maybe bad, the vnt vains maybe sticking in the turbo this is not a serviceable part and you would need a new turbo. Or the egr valve maybe going bad an not closing all the way
  8. Sega2010
    25
    14
    Aug 8, 2012
    ok ya it is a 2006 12.7 engine and doesn't have a dpf filter on it yet.
  9. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Are you sure. My buddy has an 06 shaker and it's a 14L Detroit with egr.
  10. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    The 06 I had was a 14l as well
