2006 387 cruise/transmission issues
Discussion in 'Peterbilt Forum' started by pamlee101, Jan 20, 2014.
  1. pamlee101
    pamlee101 Bobtail Member
    Hi, I'm here trying to get help for hubby with his truck. He took it to Peterbilt today and they say no codes showing and they have no idea what-so-ever what is wrong. When he has cruise on, hitting the brake does not disengage it. The other problem (we think they are related) is the automatic tranny won't engage with the brake. He has to be able to get it to roll, just a little is all it takes.
    Any ideas on what the problem is and how to fix it? Any help will be greatly appreciated.
    Thanks, pam and Levy
  3. bjytech
    bjytech Light Load Member
    247
    223
    Nov 9, 2013
    Sounds like a brake pedal switch problem, but I would think they would know to check that at a dealer
  4. JackZ
    JackZ Bobtail Member
    24
    6
    Jul 7, 2011
    Winston-Salem, NC
    We had a similar problem with our 2006, 387 with an Ultrashift automatic transmission. In that case we had a broken brake signal wire under the cab. That may not be where your problem is but your problem is definitely that the brake signal is not getting to the cruise control or the transmission controller. If they start by checking the brake light switch and then look at the wiring from there back, they should be able to find the problem.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    silly question does he have brake lights if not its switch
  6. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
  7. Rockwyrm
    Rockwyrm Bobtail Member
    15
    5
    Dec 17, 2013
    What magoo said, blew my fuse on my tractor brake lights, the cruise will not disengage. Fuse panel is under the hood.
