2006 freightliner columbia vpod problem
Discussion in 'Freightliner Forum' started by mnine55, Dec 20, 2013.
  1. mnine55
    mnine55 Bobtail Member
    16
    Detroit engine 14 L
    The truck feels like it has no power especially when going up a hill
    first time i had this problem i put a used vpod from the salvage yard, truck drove from OH to NJ ok, then when started to drive back from NJ to OH the problem started again,
    Took the truck to a mechanic he made diagnostic with his computer program, and he said the problem was with the vpod.
    this time i bought a new vpod from the freightliner dealer, again truck drove from OH to NJ ok, then when started to drive back from NJ to OH the problem started again,
    please help
    thank you
  3. QUALITYTRUCK
    1,820
    1,787
    Jun 14, 2009
    romulus,mi
    the electrical connector to the vpod is a common problem.you can buy just the connector from detroit diesel.if not,you must check continuity on each of the wires from vpod to ecm connector.good luck.
  4. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    What qualitytruck said. Check the connector to the vpod for spread pins. I have also seen quite a few vpods out of the box bad. It has gotten bad enough to where I have made a harness to bench test them before I install them.
  5. cc truck
    cc truck Bobtail Member
    Hi chip s. Was wondering if you tell me or show me how to bench test my vpod ?
