2006 Freightliner jerking when engine is warm
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Reggiesseptic, Feb 20, 2019.
  1. Reggiesseptic
    Reggiesseptic Bobtail Member
    my dad's 2006 Freightliner starts jerking when it's going down the road once the engine warms up when it's cold and runs fine but once it warms up around eight miles down the road it starts jerking kind of like a surge can anyone tell me what it is we replace the throttle position sensor someone told us that might be it but it's still doing the same thing any help on this matter would be greatly appreciated thank you
  2. secorp
    secorp Light Load Member
    292
    102
    Jan 16, 2013
    Lakeland Florida
  3. Working2party
    Working2party Medium Load Member
    458
    466
    Feb 10, 2018
    Kansas
    What engine, does it have after treatment? A 2006 shouldn’t, but want to make sure.
    Is a surge, jerk, or is it pulsing like a miss?
    Is there any chance you know what the engine temp is when it starts? Or is it at 180 -200 deg a couple miles before it starts?
  4. spsauerland
    spsauerland Road Train Member
    2,408
    6,135
    May 31, 2010
    West Harrison, In
    Sounds like an ACERT...
    fss99701 and SAR Thank this.
  5. Deere hunter
    Deere hunter Light Load Member
    198
    323
    Aug 5, 2017
    I’d be willing to bet it’s a fuel pressure problem not keeping sufficient fuel in your injector cavities so either your supply pump is getting weak or the pressure regulator on your return fuel line is getting weak !! It would help if you had a fuel pressure gauge ! But I’m totally assuming this is a cat !
  6. Easy_Money_Trucker
    Easy_Money_Trucker Bobtail Member
    48
    28
    Feb 12, 2019
    Eagan, MN
    I jerk in my Freightliner Cascadia if it's warm in the cab and I don't have the cash for an escort.
  7. fss99701
    fss99701 Medium Load Member
    327
    640
    Feb 14, 2019
    none of your business
    had a caterpillar on a Kenworth totally different animal kind of doing the same thing we took it to Kenworth after $5,000 of unneeded work a shade tree mechanic said it was the low pressure fuel pump and he was right. I guess I'm calling it by its right name the pickup pump whatever the proper name for it is, it was pretty inexpensive and it ran great after that.
  • Draft saved Draft deleted
