2006 Kenworth w900 headlight issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Legonch, Jan 7, 2024.
  1. Legonch
    Legonch Bobtail Member
    14
    7
    Nov 12, 2023
    This truck has developed a new gremlin. When I turn on the headlights, the low beams on both sides comes on fine. When you switch to brights, both lights on the right side are on, but the left side the low beam goes out, and the high beam doesnt light up.
    Being somewhat new to Kenworths, is this a relay issue? Im stumped on this one. TIA
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,957
    Oct 31, 2023
    Sounds like a bad ground on that pigtail or harness to me.
    JB7, Legonch and Hammer166 Thank this.
  4. jdchet
    jdchet Medium Load Member
    542
    771
    Sep 3, 2012
    NE Ohio
    I haven't driven a KW since my '95 T800, but the connectors on the headlight harness used to get all effed up down by the hood hinges from road slop and spray. You might try looking down there.
    JD
    Legonch Thanks this.
  5. Banker
    Banker Road Train Member
    4,567
    15,057
    Aug 19, 2012
    The first place I would look is the headlight plug connection from the hood to the chassis for corrosion. I keep a can of electrical terminal cleaner to spray on corrosion spots. I dab some dielectric grease on the connection before I reconnect them. If that isn’t the problem you will have to visually inspect the wire as far as you can for a bare spot or corrosion. If you are electrically inclined use an ohm meter to find it. It is possible to have corrosion inside the insulation without having a bare spot.
  6. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    both high beams on the one side might be burned out.
    the low beam headlight has a low light and a high light. high beam might be burned out
  7. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    I've gone through the same thing with my Pete and now my KW.
    High beam went out on one side. started chasing wires then remembered, duh. lights burn out!
