2006 Pete 387 speed sensor issues
Discussion in 'Ask An Owner Operator' started by Sbroshears, Mar 14, 2024.
  1. Sbroshears
    Sbroshears Bobtail Member
    7
    Oct 13, 2021
    Hey everyone just a quick question does anybody else know if this truck would have two speed sensors on the back of the transmission? my odometer was bouncing around all over the place so I went ahead and replace it but when I got under there, I saw an identical looks like a speed sensor directly on top with the same clip as what I was replacing but there was nothing to it and I didn’t see another harness plug-in laying around anywhere.
  3. Ridgeline
    22,778
    124,605
    I think the data for the speedometer comes from the ECM, not the sensor directly.
    Sbroshears Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    Sensor, ecm, speedo?
  5. lester
    2,959
    8,097
    Jan 2, 2012
    NW, Iowa
    my 15 uses only one speed sensor but has holes for 2. I had to replace the sensor and just used the other hole and left the original in place. was a son of a gun trying to get it out so I just left it. fyi
  6. Sbroshears
    7
    Oct 13, 2021
    OK I replaced the speed sensor and it’s doing the same thing… Any ideas?
  7. lester
    2,959
    8,097
    Jan 2, 2012
    NW, Iowa
    does it just jump around while driving or while sitting still also?
    Could be a number of things, wiring, loose connection on back of speedo, etc...
  8. Sbroshears
    7
    Oct 13, 2021
    Just when I’m moving. So it looks like my speedometer itself has gone bad. Honestly never saw that happen before. A tech looked at it and said it shouldn’t ever read below zero when it’s turned off. If it does it’s bad. I’m not sure how that affects the cruise… I thought the cruise ran off the sensors.
  9. Sbroshears
    7
    Oct 13, 2021
    Ok… not the speedometer. Still no engine break. No cruise. And when I’m on the peddle trying to remain a constant 70 I’m getting almost like a pulse surge. I’m at a loss what to do. Any ideas? Is it the ecm going out??
  10. Sbroshears
    7
    Oct 13, 2021
    New sensor. New speedometer. Still having the same issues. When I try to keep a constant speed on the peddle I’m getting a surge , almost like a pulse.
