2006 Vnl 13 speed transmission problem or injector
Discussion in 'Volvo Forum' started by believe456, Feb 20, 2021.
  1. believe456
    believe456 Light Load Member
    191
    22
    Apr 22, 2015
    I have two problems. First is when in high gear and i have to coast to quick stop (gear in neutral) without down shifting. if i put the flap down before the truck is complete stop it will grind. Is that sign of failing transmission? Second the truck shakes and rides very rough when i accelerate over 50 mph when i let off pedal it’s normal when i get back on it it very rough. I know this hard to understand but I’m just winging it
  3. AModelCat
    165,163
    Flap down? You're talking about the range selector I assume? With the 13 you'd have to pop the splitter back first before dropping into low range. Are you hitting the splitter and then immediately dropping into low range?
  4. believe456
    191
    22
    Apr 22, 2015
    Driving it like a 9. So red switch always back unless it’s a heavy load. Yes flap = range switch. Yes it grinds in neutral while coasting if i turn the range down like I’m trying to shift into wrong gear
  5. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    If i remember correctly in the Eaton video you are supposed to pre-select the high or low gear range [move the flap] so in other words when your in 4th and wanting to go to 5th you would flip flap up the shift up....same coming down...5th to 4th...flip flap up in 5th then shift down. If i remember correctly they mentioned something about not selecting it in neutral as it can possibly damage the shift fork......besides, as per your CDL training you should not be coasting in neutral to a stop.
    So if you want to do the coast to a stop make sure you range select before you come out of gear and at least clutch out of that gear into neutral and it should shift down to low range without grinding.
  6. 6cuda6
    259
    176
    Oct 9, 2020
    Second problem could be something as simple as a bad U-joint or as bad as a transmission issue....my recommendation is take it to a technician you trust and have them roadtest/verify the complaint then diagnose as drivability vibrations can get very costly so one is best not to guess.
