2006 VNL630 D12D problems
Discussion in 'Volvo Forum' started by silver dollar, Dec 26, 2017.
  1. silver dollar
    silver dollar Medium Load Member
    481
    211
    Jan 31, 2009
    Central North Carolina
    '06 D12D 435 HP, 1.2 million miles, rear main seal leaks a little, engine does have blow by. The truck has always ran good and always started up right away no matter how cold. On my last load, I parked the truck as usual. Then on the next afternoon went to start it, it cranked over but never started. I noticed coolant was down below the minimum mark, and oil level was down 1.5 gallons from the day before. So I'm thinking these low fluid levels had put the engine in a "no start" mode. So I top off the fluids, disconnected the preheater, and gave it a few shots of either and it finally started with a lot of stumbling and white smoke with the smell of unburned fuel. After it warmed up, it ran fine as usual, though I did not drive it. I then change the fuel filters, and it started without any problems. So the next day I went to start it to go drop a trailer, and again it would not start. I finally kept cranking it over till it finally started with the stumbling and the fuel laden white smoke. I notice that coolant level was down to the minimum level again but no sign of where it went.
    Can someone help me understand what's going on here. I have not driven it since the problem started. I didn't want to leave with a load and may have to be towed. Can someone offer ideas. Thanks
  3. 86mechanic
    86mechanic Medium Load Member
    373
    62,238
    Sep 6, 2016
    Northridge, CA
    Sounds like the coolant is getting into the Cylinders somehow, maybe blown head gasket. I wouldn't crank it anymore as it could hydrolock.
    silver dollar Thanks this.
  4. silver dollar
    481
    211
    Jan 31, 2009
    Thanks for the reply. Well I went today to see what it would do today. I would not start. I had to spray it again. But before I started it, I check the oil and coolant. Oil was full but the coolant reservoir was nearly empty. I drove it a few miles and it ran good. The other day when I change the filters, I let the spin on fuel filter drain into a bucket. I check it today and there was about a half pint of antifreeze in the container. So is my coolant getting into the fuel? How is this possible?
  5. 86mechanic
    373
    62,238
    Sep 6, 2016
    Northridge, CA
    Does it have a Davco fuel filter with the fuel heater?
  6. silver dollar
    481
    211
    Jan 31, 2009
    Yes it does have a Davco. When I drained to to change the filter, there was only about 2oz of water in the bottom... no antifreeze.
  7. 86mechanic
    373
    62,238
    Sep 6, 2016
    Northridge, CA
    So where was the antifreeze, in the water separator?
  8. silver dollar
    481
    211
    Jan 31, 2009
    The antifreeze was in the spin on filter.
  9. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    Injector cups leaking. Coolant getting into fuel supply. This is also the cause for your hard start. Your missing coolant is in your fuel tanks.
  10. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    Wow....I'll be dah-mned.
    This never crossed my mind.
    To OP, Maybe check your fuel gauge, or buy a ruler to measure the volume of the tanks. Is there a test kit for checking water in the fuel?
  11. 86mechanic
    373
    62,238
    Sep 6, 2016
    Northridge, CA
    But isn't fuel at higher pressure then coolant? So it would push fuel into coolant, versus the other way?
