2007 columbia electrical problems
Discussion in 'Freightliner Forum' started by RTSTRANSPORT, Mar 6, 2014.
  1. RTSTRANSPORT
    RTSTRANSPORT Bobtail Member
    5
    North Bergen, NJ
    Hello guys ,I have a 2007 Columbia, the truck drives fine for two days then oil pressure gauge drops,water temp gauge drops as well and fan clutch goes on together with check engine light not to mention a massive power loss the truck won go over 15 MPH and then starts working normal .I replaced both main wiring harness and the one that goes from batteries to ECM.I really need help I don't know what to do anymore .thanks in advance .
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    It sounds like a loose connection, bad ground. Did you check the battery cables to starter to frame, it could be loose or corroded.
    tirednaz Thanks this.
  4. RTSTRANSPORT
    5
    North Bergen, NJ
    The starter cables come from the harness that plugs into the firewall to the ECM and that harness has a plug that runs the wiring to the batteries all that has been checked all grounds to the ECM are tight and secure both main sensors harness and main harnesses that plugs into computer 860.00 buck for the two have been replaced this truck is driving me crazy.even at idle runs for hours perfectly and all of the sudden fan clutch goes on I run to see the dash and guess what check engine light is on and everything else that I mentioned happens at the same time.Thanks in advance for your help .
  5. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    does your truck have wiring left over from a qualcomm unit that may have been installed at one point?if so,look outside,rear upper left roof line for old black antenna cable.green,corrosion at end of open cable.quick fix is to cut cable until you are able to follow and disconnect old wiring.good luck.
  6. RTSTRANSPORT
    5
    North Bergen, NJ
    I was thinking of that, im going to check when I get to the yard since this was a company truck ,I have a volvo as well and it was doing something similar but no loss of power and in fact was that wiring that you just mentioned,I really appreciate you took the time to help me .ill keep you posted and have a good day
  7. RTSTRANSPORT
    5
    North Bergen, NJ
    Hey qualitytruck thanks for your lead in fact was the qualcom
    Wiring what was causing the problem incredible how that harness
    Would power down the truck .I was going nuts.Thanks again
  8. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    you are welcome.glad to help.
