2007 cummins isx low overall boost EXCEPT...
Discussion in 'Ask An Owner Operator' started by CLP Trucking LLC, Dec 9, 2022.
  1. CLP Trucking LLC
    CLP Trucking LLC Bobtail Member
    5
    4
    Nov 27, 2015
    I've got a 2007 cummins isx with overall low boost. Ive been having this truck for 7 years and boost gauge usually reads 30+ while under a load. I noticed for the past week I can only get about 15 psi on my gauge while under a load EXCEPT right after I use my jake brake. For instance, if I'm coming down a slope and use my jake to help slow the truck then once i get back on level ground and can accelerate again, at that moment, I have full boost, 30+ on my gauge, but it only last for 15-20 seconds then its right back to 15psi max. The only other time that i can think of where my boost goes to ALMOST normal is while pulling an empty trailer and I go into 6th gear (i have a 13 speed), at that moment i can get to about 25 on my gauge but it falls back to 15 in about 15-20 seconds.
    Is there a connection with the jake and the turbo. and please forgive my ingorance on how a jake brake works. The turbo sounds normal, I've checked all clamps and rubber boots for leaks and can't find any. The turbo is not leaking any fluids. egr has been deleted from ecm
    I have no check engine light on, so far I've replaced the turbo actuator and the barometric pressure sensor, under the advice of a local "parts changer" ( i say parts changer because the mechanics here aren't very good at diagnostics). I hate to keep throwing sensors and parts at it without a clear direction and like i said, there is no check engine light.
    Should i get my ecm scanned anyway in hopes that there will still be some clue as to where to look? I was thinking maybe someone here has had a similar problems with a similar engine before and could help to lead me in the right direction.
    Thanks
  3. NYStarcar
    NYStarcar Light Load Member
    249
    595
    Oct 6, 2020
    In a van down by the river
    Is it effecting the drivability or is it just showing low on the gauge?
  4. Siinman
    Siinman Road Train Member
    5,543
    14,259
    Mar 5, 2017
    Kansas City, MO.
    How does the air filter look has it been changed lately? Seems you have some kind of restriction maybe?
  5. Ridgeline
    22,774
    124,521
    Check your fittings and the CAC. you more likely have a leak.
    CLP Trucking LLC and Siinman Thank this.
  6. CLP Trucking LLC
    5
    4
    Nov 27, 2015
    Found an exhaust leak from one of the exhaust manifold gaskets. Almost a half inch break in the gasket. I hope this is the culprit
    dosgatos and Siinman Thank this.
  7. CLP Trucking LLC
    5
    4
    Nov 27, 2015
    It’s definitely effecting the drivability, no power while under a load
  8. Andy_S
    Andy_S Bobtail Member
    Have you resolved the issue? Was it the leak from one of the exhaust manifolds? I’m experiencing a very similar issue.
