2007 International 4200 AC issues
Discussion in 'International Forum' started by trent001, Jan 6, 2021.
  1. trent001
    trent001 Bobtail Member
    6
    Jan 6, 2021
    I have a 2007 International 4200 with a VT365 engine.
    Recently while driving the check AC light came on and I no longer had working cold AC. I read the codes from the dash and it flashed two fault codes.
    1:7
    613_14A
    150:1
    2023_14P
    I believe the first one is active and for low refrigerant?
    When the engine is running with the AC on max the compressor clutch is not kicking on. If I do a jumper wire and hook the compressor to 12V the clutch will engage. I have already put one can of R134a into the system and am having the same problem. Should I add another can? How much does the system hold?
    Any other suggestions/ideas? Is this the correct approach?
    @Heavyd
    Trucking Jobs in 30 seconds
  3. trent001
    6
    Jan 6, 2021
  4. Heavyd
    Heavyd Road Train Member
    7,115
    5,240
    Feb 4, 2009
    AC on those is computer controlled. I would get the codes read by a proper scanner and troubleshoot from there.
    Farmtractor9900 Thanks this.
  5. trent001
    6
    Jan 6, 2021
    @Heavyd as you suggested I purchased a Nexus NexLink NL 102PLUS. My problem now is that is does not turn on or read. I can plug it into other vehicles and it works just fine. Now what?
  6. Heavyd
    7,115
    5,240
    Feb 4, 2009
    Never heard of that. We use Nexiq USBLINK-2 on our laptops running Diamond logic builder software.
  • Draft saved Draft deleted
