2007 International pro star Suspension dump switch flashing
Discussion in 'International Forum' started by Warslobo, Aug 19, 2022.
  1. Warslobo
    Warslobo Bobtail Member
    OK I've traced 2 Orange lines from the control Box back to the leveling valve 1 large 1 the supply and then there's a smaller line that does not connect to anything coming Back to the leveling valve there is also a black small line coming off the leveling valve does not connect anything
  3. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    1st mine does that from time to time. When it does I just flip it to dump and back, it stops flashing...
    The other thing is the electric controller may be bad... it's on the inside of the frame (driver side).2 relays (1 to dump & 1 to fill) side by side... 1 may be bad... the 2 in the middle control the levering valve
    Heavyd Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    It will flash when the computer is detecting an electrical problem with the wiring or solenoid packs. Like mentioned above, it is common for the connection between the solenoids and the pack base to become corroded and cause problems like this.
  5. de la cruz
    de la cruz Bobtail Member
    I have 2006 international I have a similar problem the suspension only dum but is not going up not how you mentioned probably is because bed relay ore bed solenoid were I find the relay on the 2006 intert
