2007 Mack Ctp713b
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Seb00, Oct 18, 2022.
  1. Seb00
    Seb00 Bobtail Member
    4
    Oct 8, 2022
    Just was in the middle of replacing the fuel/power steering pump was sold a different 2007 mp7 pump with a bigger gear. Took it back received a correct sized pump however the power steering pump opening was a fine thread instead of a course thread like the old pump. Mack could not find the fitting??? Any ideas?
    Magoo1968 Thanks this.
  3. Magoo1968
    Magoo1968 Road Train Member
    2,062
    5,493
    Mar 18, 2021
    St Malo mb
    Brettj3876 Thanks this.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Know nothing about the new Mack Volvo stuff
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,556
    6,643
    Aug 26, 2014
    Picture 3 looks like O-ring boss.
    Picture 2 looks German to me and would use a small diameter o-ring. A good hydraulic shop or John Deere may have a fitting for that.
    AModelCat Thanks this.
  6. Seb00
    4
    Oct 8, 2022
    Thanks appreciate everyone's reply. I went to a fabrication shop and had one made. Mack did find one with fine thread, but the output hole was only 5/8. The original was 1". If I did use the 5/8 I would have to change the line and fitting to the reservoir. Question would be how would it affect the output flow?... In anycase it was easier just to have one made...
  7. AModelCat
    165,108
    On the outlet it would have next to no effect in volume moved. Pump will always move X amount of fluid per revolution. It'd just speed up the velocity of the fluid, which creates friction (heat).
    I'd bet that fitting you needed was metric or DIN.
