2007 Peterbilt 379 with a C-15 Cat Starter issue
Discussion in 'Peterbilt Forum' started by Six Iron, Feb 5, 2019.
  1. Six Iron
    Six Iron Bobtail Member
    i have a 2007 Peterbilt 379 with a C-15 Cat. I bought the truck last November. About three weeks ago, I went out to start the truck and got everything but no start. Relays were coming on, plenty of power but nothing when I clicked the key to start. I tapped on the starter and it fired up. I took it to Kenworth in KCMO to have a new starter put on it. They were the only ones to get me in. The put a new Remey starter on and I headed out. 5 days later in Texas I shut the truck of to fuel and check fluids and it did the same thing, only this time tapping the starter did nothing. Service truck pulled me out from under the trailer and we roll bumped the truck. Took it back to KC and the went through, they say everything and put another starter on. A week later and I am in Cleveland and it has done it again. Can anyone give me anything as to why all the sudden I am going through starters.
  3. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Prob just the starter relay.??? Not sure where they are on a pete though.
  4. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Have you tried to jump the solenoid? With the workmanship of everything these days you can get a new bad starter.
  5. AModelCat
    166,336
    I have my doubts it was the starter that caused the original problem as it has now done it with 2 replacement starters as well. I'd be doing some digging with a multimeter to see if you're getting power down to the starter solenoid on the ignition power wire. If no, your problem is somewhere between the key switch and the starter solenoid (including starter relays and whatever else is wired into the circuit).
    Tombstone69 and pushbroom Thank this.
  6. pushbroom
    pushbroom Road Train Member
    1,791
    7,405
    Sep 1, 2012
    Starter relay is located on the driver side firewall.
  7. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Might even be the key switch, that's what multimeters are for.I don't know why but a lot of mechanics either can't grasp or are scared to death of electricity.Me,I always start with the batteries.
