2007 Volvo ac problems/ fan clutch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DHS RCN, Jun 25, 2020.
  1. DHS RCN
    DHS RCN Bobtail Member
    I have a 2007 Volvo vnl the radiator fan won't stay engaged with the AC on so the high side pegs the 350 mark and cuts the compressor off. The research I've seen says the high-side switch controls that wondering if it's a two-part switch because they switch works and cuts the compressor off at 350 fan clutch works when you first start it and if the temperature gets to 210 it will kick in and bring it back down so I don't think it's a clutch issue. Anybody familiar with this? Any information is appreciated.
  3. bad-luck
    bad-luck Road Train Member
    3,441
    6,339
    Nov 16, 2013
    Baltimore, Maryland
    There are two pressure switches. One tells the engine fan to turn on, that one is on the high side. The other is on the low side and tells the compressor to turn off
  4. DHS RCN
    Thanks for the help but doesn't the high side tell the compressor to cut off as well if the high side pressure is to high? ( If so that part works) but that same sensor does it tell the fan to come on too? Is it a two part switch? Meaning can it work to tell the compressor to cut off and not work to tell the engine fan to come on when the pressure is high enough to need the fan?
  5. bad-luck
    3,441
    6,339
    Nov 16, 2013
    Baltimore, Maryland
    Ok, usually the sensor is mounted near the radiator on the ac line for the fan high pressure sensor. It should do both to prevent compressor damage
