2007 Volvo Vnl 670 Cummins ISX turbo issues
Discussion in 'Ask An Owner Operator' started by sjclement95, Nov 21, 2022.
  1. sjclement95
    sjclement95 Bobtail Member
    4
    Hey guys I have a 2007 Volvo Vnl 670 with an Cummins Isx engine I have to warm the truck up fully then shut it off and fire it back up for the turbo to spool. Is this the turbo wastegate actuator or it could it be something else?
  3. snowwy
    snowwy Road Train Member
    20,650
    13,374
    Jul 6, 2009
    Turbos didn't last long on isx motors of that time frame. If you have someone in your area that rebuilds Turbos. It be cheaper then installing a reman.
    2 companies I worked for always had spares.
    A shop can run diagnostics on the turbo. A bad sensor might also be the problem. I had one instance where the delta sensor went bad. Stopped the turbo from operating. I had to limp 150 miles to civilization. Rush truck centers diagnosed and replaced the sensor.
    sjclement95 Thanks this.
