2007 w900 kenworth, when I push the brakew pedal its like the brakes have a delay, the truck starts to slow a little then after about 3 seconds it starts to slow like it should. Any ideas?
2007 w900 brake issue
Discussion in 'Kenworth Forum' started by southtx, Aug 30, 2011.
U might check brake adjustment an might also depend on what u driving before all models are different
Have you replaced a relay valve lately? Maybe one is on the way out.
i would check your relay valves and it would be good practice to blow down your air tanks every night when you shutdown. water reeks havoc on the rubbers in all the valves in the air system.
also when was the last time you greased everything?
I have replaced alot of treadle valves on the newer trucks and also the plunger under the pedal might need to be cleaned up and anti seized
