2007 W900l air conditioning issues
Discussion in 'Kenworth Forum' started by ROBSREDFORD, May 10, 2016.
  1. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    140
    Sep 2, 2008
    MIDLAND, NC
    07 kW Daycab has new drier new expansion valve and new orings Idling it blows cold but going down road it gets warm. Water valves are off and I have clean evaporated core and heater core...... Also blower fan seems fine at box but barely blows out vents. Thanks in advance
  3. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Do you have a condensation drip from the box? If not, the drain is stopped up and filling the box up with water. Should also produce a stale, fishy smell.
  4. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Does the air flow change when you move the fan speed switch? Are the blower fans correctly mounted on the motor shaft? I bought a W9 once and someone had reversed the fans. It would blow but not very well. Is the resistor good?
  5. Sipesh
    Sipesh Medium Load Member
    617
    1,101
    Apr 3, 2014
    Colorado
    Just wondering, have you have the Freon level checked? And has the cab air filter been replaced? I have a 2007 W900 myself. Air wasn't doing so great, would blow warm as the truck heated up, but it just needed a Freon recharge in my case, luckily.
  6. AModelCat
    164,941
    Probably a blocked drain from the evaporator core. Usually the moisture drips out the tube as it forms but if its blocked it will accumulate and form a block of ice that restricts air flow out the vents as well. Had that happen little over a week ago. Cleared out the drip tube and had almost half a gallon of water come pouring out.
  7. ROBSREDFORD
    266
    140
    Sep 2, 2008
    MIDLAND, NC
    Drain line is clear....r134 is at spec....we had it completely empty to replace drier etc... As far as fan...where is this filter you speak of...,
  8. AModelCat
    164,941
    What model?
  9. ROBSREDFORD
    266
    140
    Sep 2, 2008
    MIDLAND, NC
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    All the KW ' s I have owned from 99 to 07. I have had to charge the freon half a pound less than what is required to keep it from doing what your having trouble with.
  11. AModelCat
    164,941
    I guess I should have read the title lol.
    Usually cab filter is an add on option. If you have one it'd be screwed on over the mesh on the passenger side cowl, by the air cleaner. If you don't have one its a good idea to get one. In dusty conditions you'll take out blower motors on an alarming basis.
