2008 c15 engine brake
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mrtceo, Sep 10, 2012.
  1. manasteel
    manasteel Light Load Member
    124
    32
    Sep 10, 2012
    the rocker shaft studs are not relevant to oil supply on the acert. however you can identify the newest version of the stud by removing one, if it is a straight shank all the way up you should replace them, they will break. if it is machined thinner under the hex of the stud approx 1" long you have the latest stud version. you should check them all to be sure.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    not to argue but yeah one of the studs does supply oil the the jake on an acert. well maybe not the three studs but the one that looks like a bolt. that goes down through the rocker shaft.
  4. manasteel
    124
    32
    Sep 10, 2012
    my bad yes just the bolt
  5. mrtceo
    mrtceo Bobtail Member
    12
    Sep 10, 2012
    PA
    Mechanic ran out of time this weekend. Nothing electrical, tighten up actuator and jake plugs with O rings, cleaned oil out of them with brake clean as well. No change. He said there are other possible oil supply issues, since the head is supplied by one 3/8 port, which also comes out of the supply for the accessory drive. If bushings are loose in drive gears, could be taking oil from the supply to head. First thing affected would be the last thing supplied, which is the engine brake. The bolts in the housing are all correct as well. Oh well. Nothing is ever easy anymore.
  6. Jas
    Jas Medium Load Member
    Is it weak on all jake setting or does it just feel like you've dropped one bank?, does it sound weak or feel weak? there is a difference.
    Above all else make sure the overhead clearnaces are right, after that-
    If they sound weak-
    If the jakes are weaker than unsual on all 3 settings you most likely have an oil supply issue, look for a spun cam bearing, or a massive oil leak under the rocker covers, maybe a missing gallery plug in a jake/IVA housing.
    Typically a cracked housing will only result in one weak bank but if they're broken bad enough you will see all the jakes get weak.
    Something else I've seen but is unlikely in this case since they were ok for a while after the work was performed is one or more rocker shaft installed upside down, that creates a big oil leak.
    It isnt possible to put the bolts in the incorrect order to block the oil supply to the jakes on the Acert as the housing prevents the studs and reduced shank oil supply bolt being mixed up.
    If they sound ok but a feel like they are weak in operation-
    Check for boost leaks and turbo condition, good jake operation requires good boost from the turbos, if you aren't getting the boost they will be weak.
    mrtceo Thanks this.
  7. mrtceo
    12
    Sep 10, 2012
    PA
    He mentioned the possible spun cam bearing. weak on all settings. when he ran it with the valve cover off he said there wasn't any visible excessive oil coming out of anything. Gonna have to make some time and take it apart. I'll keep posting updates. I appreciate everybody's info.
  8. Jas
    There is a tool you can get for jake brakes to measure the pressure supplies to the jakes, it screws in where the solenoid goes, unfortunately the Cat brake doesn't have that option, you can measure oil pressure at the air compressor feed line, the will at least tell you there is supply to the top end but the cam bearing and idler bearings are downstream of this point so you would have to check those things the hard way. Has anyone cut and insepcted the oil filter? If you have a spun cam or failed idler bearing there should be some metal in the filter.
  9. mrtceo
    12
    Sep 10, 2012
    PA
    Now I have a fault code for "Intake Valve Actuator 1". Engine brake still acting up but sounds just a little different. Lost about 8 to 10 lbs of boost pressure since code came up, and can smell some blow by that I never noticed before. Turned around and came home, have 12:30 appointment at KW dealer. (it's a pete, FYI)
  10. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Mine went into the garage last nite for the same thing (BSX) 5-6 actuator code I got over 1,000,000 on mine. My CEL blinks if tou hit a bump just right, I thinking harness I'll let you know as soon as I find out.
  11. mrtceo
    12
    Sep 10, 2012
    PA
    BSX is '02-'03 year?
