2008 freightliner sport chassis m2
Discussion in 'Freightliner Forum' started by Rollin_coal, Oct 19, 2013.
  1. Rollin_coal
    Rollin_coal Bobtail Member
    9
    I have a 2008 freightliner m2 cummins with Allison auto. Truck runs fine. 39,000 miles. Was in hurricane sandy flood. When you try to put the truck in forward or reverse it doesn't move. I bought the truck like this. It seems the trans is blown. The shift selector is cable driven and you can see it moving the lever on the side of the trans. Do I have an electrical problem? Should the truck move?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    pull the pan and see whats in the bottom.
  4. Rollin_coal
    9
    It's clean. Is the trans computer controlled? Should it still move is it had an electrical pproblem?
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Sound like the valve body is stuck. May want to try something like Lucas trans conditioner , or some thing the like. Try to free them up. If that don't work , your going to have to dive it any way.
  6. Rollin_coal
    9
    If the trans is good, would there be something else keeping it from going into forward or reverse?
  7. Fatone
    Fatone Bobtail Member
    15
    Jul 11, 2013
    Before pulling pan check and see if brake shoes are rusted to drums. If they are build up air release brakes hit drums with hammer to break loose. Be sure to chock wheels before doing this, Good Luck
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    First thing you want to do ASAP is take as much of the truck bottom off as possible and power wash it out to try and prevent corrosion. (or drive in a fresh water lake as deep as the flood was if you can get it rolling) My guess (havnt worked on these before, so truly a guess) is water got into the electrical systems of the trans or linkages and corrosion started. Unfortunately unless you clean every where flood water touched, you will continue to have problems.
    I had a jeep get flooded in Huriccane irean a few years back. Right after the flood, i took it to a fresh water lake and drove around in about 3 foot of water. Never had a problem since. The water isn't the problem, its the corrosion of salt water. If you can clean it with fresh water real good you should be able to fix it. Anything with corrosion needs to be cleaned. Cables, connectors etc, replaced. Corrosion is like a virus, unless you get it all it will just come back.
    That beign said, is the trans throwing any codes? That'd be a start. Good luck...I hope you got a good deal on the truck and if you can get it cleaned up you may have gotten the deal of the century on a low mile truck.
  9. Rollin_coal
    9
    The truck rolls fine. Has 3 computer codes when you use the select button in the digital dash. Sid 250, Sid 254, noj 1587. The first two codes are for abs I think. And the third is gauge cluster comm failure I think for the water temp and oil pressure
  10. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I've heard driver with auto not being able to get the trans in gear if one wire was broken or connection loose. Yes electrical problems can trump mechanical in this case. Assuming no water got in the trans (it could have depending on depth) the trans should be mechanically ok.
  11. Rollin_coal
    9
