2008 Maxforce DT7 code help and cylinder down issue
Discussion in 'International Forum' started by Breathless, Jul 8, 2019.
  1. Breathless
    Breathless Bobtail Member
    7
    Jul 5, 2019
    We got this truck not long ago and already issues. We had cylinder 3 have bent pushrods both intake and exhaust. We replaced the pushrods and did the lash and all was good till about 500 miles later while driving all of a suddun the engine started shaking and feels like it did before. Is this a common problem? or is there a fix so the rockers dont pop off.
    No I got the codes
    sid 427 FMI 3
    sid 420 FMI 1
    sid 420 FMI13
    SPN 3981 SA33 FMI2
    SPN 4026 SA 33 FMI5
  3. Heavyd
    Heavyd Road Train Member
    7,626
    6,027
    Feb 4, 2009
    The lifters get stuck in the block and jam then the piston hits the open valve and does the damage. Engine replacement is the fix.
  4. Breathless
    7
    Jul 5, 2019
    Is it a clearance issue with the lifters and replace the lifters? Why would you repalce the engine if the same thing can happen there as well?
  5. Heavyd
    7,626
    6,027
    Feb 4, 2009
    Lifters ride in the block, the block is ruined.
