Hi,
I am looking at a 2009 truck with 60,000 miles that has the following fault codes. Any insight on these and what would be involved to repair would be appreciated.
Active Fault Codes: 593-14, 111-1, ABS 2-5 Noted On ECM, ABS 30-4 Noted On ECM
2009 DT466 code help
Discussion in 'International Forum' started by Treetruck79, Feb 19, 2017.
593-14 means engine was shut down to idle shut down. This is not a fault.
111-1 is for low coolant. 2009 you should have a Maxxforce engine there. Low coolant is very common with EGR coolers failures.
Need to know what type of ABS you are dealing with. -
Thank you -
Ok, you do have first generation Maxxforce. Your brakes are Meritor Wabco full power hydraulic.
2-5 right front sensor circuit error. Wiring or sensor problem.
30-4 is internal error for the valve relay can't switch on. You will get this code with power or ground supply problems, or failed ABS ECU.
