2009 freightliner cascadia with Webco ABS system, abs light on
Discussion in 'Freightliner Forum' started by matthew99, Jan 4, 2019.
  1. Rideandrepair
    17,633
    57,060
    Aug 8, 2015
    Better yet I looked again and found your code:: excessive wheel slip. Check air gap on sensors. Doesn’t say which ones to check.You can try to push them in with a long flat punch. Not too hard as you don’t want to damage cable while doing it. Unless you just spun the wheels and caused the light to come on. If so it should go off after starting up and moving 5 + mph
  3. Rideandrepair
    17,633
    57,060
    Aug 8, 2015
    Aside from a sensor needing to be pushed in. A bad sensor or cable to the sensor, a loose or bad wheel bearing can cause excess end play and knock the sensor away from the exciter ring. Something serious to check out if it doesn’t go away or keeps coming back on
  4. matthew99
    matthew99 Bobtail Member
    13
    Jan 4, 2019
    It’s been on since I got the truck in September, I’ve had kingpin bushings replaced and they said the wheel barring was a little loose on the right side due to a bad locking nut , I’ll start with the steer axel and work my way back. Thanks for all the input, btw I went to a shop today and had them hook the computer up to it, needless to say that got me nowhere. All the computer said was the abs light was on.
    austinmike Thanks this.
  5. Rideandrepair
    17,633
    57,060
    Aug 8, 2015
    Try pushing the fronts in they’re easy and can be changed w/o taking wheel off.I just had that on mine just pushed front one in. Also had a bad wire from RR to valve. After replacing sensor and aluminum bracket that holds sensor. They break easy. Look for broken wires. Mine showed excessive gap/ open circuit, was a bad wire
  6. Rideandrepair
    17,633
    57,060
    Aug 8, 2015
    You know there’s a button or switch you can hit to get a blink code right? I assumed you already did that.
  7. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    It might be the bearing.
  8. matthew99
    13
    Jan 4, 2019
    I’ve read there’s one but not sure where it is
  9. matthew99
    13
    Jan 4, 2019
  10. matthew99
    13
    Jan 4, 2019
    I did get one on the front to push in but that changed nothing. Going to test all the sensors, ck wheel barrings and get everything cleaned up real good
  11. 201
    201 Road Train Member
    13,045
    26,951
    Apr 16, 2014
    high plains colorado
    WHAT? Bad locking nut on the bearing and wasn't fixed? :eek: How does a locking nut go bad? That's scary enough.
    daf105paccar Thanks this.
