2009 freightliner M2 Cummins Turbo replacement
Discussion in 'Freightliner Forum' started by Rjackson9293, Nov 15, 2018.
  1. Rjackson9293
    Rjackson9293 Bobtail Member
    Hello, first time here. I recently started working in the diesel field after about 14 years in industrial maintenance so I’m learning as I go. My question: I’m about to replace a turbo on a 2009 freightliner santiogo m2 with a Cummins. Do I need to calibrate the turbo in any way or is it just plug and play? Thanks in advance
  3. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    Yes you do. The new turbo will not come with an actuator. If old one is good you can still use it. With Insite you have a turbo calibration feature that you follow to do it correctly.
